jc2010
Jan 28, 2011Aspirant
Backup Connection Error
I'm trying to backup my PC (Windows Vista, 64-bit) using Frontview. The PC and ReadyNAS are both on my local home network, and I don't have a login/password on my computer. I've selected "Remote: Wi...
Jun 16, 2013Guru - Experienced User
Just to be clear... you can access the windows folders you are trying to back up from other Windows machines, but frontview backup fails on test connection?
Also did you try the backup anyway? Sometimes test connection fails but the backup works. BTW frontview help gives some useful hints on syntax (slashes, etc).
