jc2010
Jan 28, 2011Aspirant
Backup Connection Error
I'm trying to backup my PC (Windows Vista, 64-bit) using Frontview. The PC and ReadyNAS are both on my local home network, and I don't have a login/password on my computer. I've selected "Remote: Wi...
stgeorge
Jun 16, 2013Guide
You can also try just entering the ip address of the share to be backed up (assuming it is on the same lan and workgroup, and will be more reliable if you have that ip address set as fixed). So enter 192.168.xx.xx/share name and see if that works.
