superandy07
May 17, 2016Aspirant
Backup Error with RSync - Permission denied
Hi, Hi, I’ve been having issues recently with backing up my Ubuntu server to my ReadyNAS 102. I think what the issue is I use OSX on my main machine, this creates metadata files/folders on t...
mdgm-ntgr
May 18, 2016NETGEAR Employee Retired
Which firmware are you running?
Which version of Rsync are you running on the Ubuntu server?
- superandy07May 18, 2016Aspirant
ReadyNAS Firmware 6.5.0
RSync on Ubuntu 3.1.0
- mdgm-ntgrMay 19, 2016NETGEAR Employee Retired
Can you update to Rsync 3.1.1 and see if that makes a difference?
- superandy07Jul 07, 2016Aspirant
I finally got round to this, updated Rsync to 3.1.1, still have the same problem.
I dug around a bit on Google and found this thread -
"ReadyNAS is trying to preserve permissions on files when transferring them over to FreeNAS, but is having a problem changing group ownership for some files (mostly OS X resource forks it looks like). Besides that looks like the files transferred over OK! You can ignore these errors, but annoyingly they'll still cause a backup job to show a "failed" status."
Someone on there mentioned “Enable FAT32 compatibility mode”, but I can’t see that option for my backup job.
Still need to figure out why ReadyNAS isn’t deleting files that are removed on the server.
Here’s the current settings -
http://i.imgur.com/tSHGZHC.png
http://i.imgur.com/Khagd4w.png
http://i.imgur.com/qQ41uda.png
