superandy07
May 17, 2016Aspirant
Backup Error with RSync - Permission denied
Hi, Hi, I’ve been having issues recently with backing up my Ubuntu server to my ReadyNAS 102. I think what the issue is I use OSX on my main machine, this creates metadata files/folders on t...
mdgm-ntgr
May 18, 2016NETGEAR Employee Retired
Which firmware are you running?
Which version of Rsync are you running on the Ubuntu server?
superandy07
May 18, 2016Aspirant
ReadyNAS Firmware 6.5.0
RSync on Ubuntu 3.1.0
- mdgm-ntgrMay 19, 2016NETGEAR Employee Retired
Can you update to Rsync 3.1.1 and see if that makes a difference?
- superandy07Jul 07, 2016Aspirant
I finally got round to this, updated Rsync to 3.1.1, still have the same problem.
I dug around a bit on Google and found this thread -
"ReadyNAS is trying to preserve permissions on files when transferring them over to FreeNAS, but is having a problem changing group ownership for some files (mostly OS X resource forks it looks like). Besides that looks like the files transferred over OK! You can ignore these errors, but annoyingly they'll still cause a backup job to show a "failed" status."
Someone on there mentioned “Enable FAT32 compatibility mode”, but I can’t see that option for my backup job.
Still need to figure out why ReadyNAS isn’t deleting files that are removed on the server.
Here’s the current settings -
http://i.imgur.com/tSHGZHC.png
http://i.imgur.com/Khagd4w.png
http://i.imgur.com/qQ41uda.png
