Valleypeach
Jan 09, 2014Aspirant
Backup from PC to ReadyNAS over wifi
hello, we are attempting to set up a backup job using the backup app that came with ReadyNAS 102. It is brand new, all firmware is up to date, we are running windows 7, all updates installed. Everythi...
Valleypeach
Jan 10, 2014Aspirant
StephenB,
Thank you for the reply. My suspicion regarding use of term "remote" is clarified.
Upon reflecting on your comment about how you back up your PCs, this now makes much more sense and I can see that the solution is not so much SIMPLE as it is OBVIOUS.
We will check out the Acronis app. Thx for the tip!
Best regards,
Val.
Best regards,
Val.
