norliss
Jul 20, 2016Aspirant
Bad Firmware solution/alternatives?
I've recently been having problems with my trusty old sparc NV+. A couple of weeks ago it got stuck booting, after running through memory tests etc eventually it reported a bad disk. I removed all th...
norliss
Jul 22, 2016Aspirant
Hi JennC and thanks very much for replying to my message.
I totally hear you on the back-up. The NAS was mostly used to stream music via Logitech Media Server and my music catalogue is backed up multiple times, so that's no worry. Alas the "Video" portion (films ripped from my own DVD/Blu-ray) isn't: I still have the original discs but not the appetite to re-rip them all, but hey. I did have a quick look on ebay for Sparc NV+ units but they're not exactly in great supply, which is hardly surprising given their age.
When you mention a "scratch disk" is this because the suggestion would be to carry out a full factory reset? This is the one thing I have yet to try and I suppose it's the only thing left for me to try now, given none of the other options have been successful....
Jul 22, 2016Guru - Experienced User
Correct. Doing a fresh install with a scratch disk would verify the chassis while keeping your data intact.
Another thought - you could mount the array in an x86 linux system (or a PC booted from a linux live cd), and copy of the data that way. http://home.bott.ca/webserver/?p=306
- norlissJul 22, 2016Aspirant
Hi,
Just did a factory reset with a scratch disk and all went well insofar as it booted and I was able to access the admin tool etc.
However, I've since reinstalled the original 4 discs (in correct order) and I get the old "Bad Firmware" message again. I've tried powering down and rebooting each time with a different disc removed to no avail. I don't get this as I've tested each of the discs individually with the Seagate disc tools and there are no issues reported with any of the discs!
- davexyzJul 22, 2016Aspirant
I am currently going through this with one of my v1 NAS units. bad firmware. Did usb os install which worked but when I booted back to bad fiormware message alo did straight os install same result.
Eventually did a memory test and despite it passing I swapped out for new memory, 256k , rather than the Igb that I had upgraded to and It now boots correctly.
Worth trying
Hey davexyz, thanks for this.
The NAS seems to be working ok with a spare 750GB drive I have (but not with the 4x2TB drives I was using until recently) which makes me wonder if it is the NAS or the drives.
That said, I am tempted to get some new memory to try this out. Perhaps I'll get it from Amazon and return it if it doesn't do the trick!
