zero11
Oct 13, 2016Tutor
Bad NML Call code 22002010000 OS 6.6.0 Qbittorrent
I upgraded to OS 6.6.0 and got the "Bad NML Call" error code 22002010000 with Community App QBittorrent though that app is not listed on the page of Community apps with known errors with 6.6.0 ( http...
mdgm-ntgr
Oct 13, 2016NETGEAR Employee Retired
Which version of that app did you have installed?
Which other apps are you running?
Can you send in your logs (see the Sending Logs link in my sig)?
zero11
Oct 13, 2016Tutor
Sorry, neglected to answer: Other Apps running: only "Anti-Virus Plus". I use ReadyNAS Replicate with it for daily backups (it's the target) if that's of interest.
- mdgm-ntgrOct 21, 2016NETGEAR Employee Retired
Seems to be running now. I guess you could have installed the newer app from Addons available For R6 via the Upload button on the Apps tab of the web admin interface then tried starting the app again.
- zero11Feb 08, 2017Tutor
I'm running firmware 6.6.1, but still get that "bad NML" error if I try to install qBittorrent ( qbittorrentr6_3.3.0_amd64.deb ) from https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC What needs to be done, so this will work?
