_Orion's avatar
_Orion
Balancing Volumes makes drives unusable
I started a balance on my ReadyNas 10200 a couple of days ago thinking it would not take long, but it has become unusable since and I would just like to abort the whole process. I have a 2TB and 4TB ...
  • StephenB's avatar
    Dec 02, 2015
    Once you get ssh running, you can cancel the balance using the info here: https://community.netgear.com/t5/ReadyNAS-in-Business/ssh-command-to-stop-balance/td-p/994979
    Are you running 6.4.0?  If so, I'd upgrade to 6.4.1 and restart after you cancel it.  The NAS should then remain usable during the balance.
    You can't shift the 4 TB drive to a PC, it doesn't support the BTRFS file system. The best option there is to get another 4 TB drive, and replace the 2 TB one.
    Another choice is to backup the NAS, switch to flexraid and destroy the current volume.  You can then remove one of the drives, or create 2 volumes (one on each).
ProSupport for Business
