stunod2002
Dec 23, 2014Aspirant
Best use / max performance for dual LAN
I have the 2100 rack mount and would like to take advantage of the dual LAN on the device. Simply connecting both NIC's to the switch (A NTGR managed switch) will not do the trick I suspect. The main ...
Nhellie
Dec 23, 2014Virtuoso
As far as I know, when using trunking on the ReadyNAS it does not really combine the two ports as one. It is more like load-balancing instead. (Please correct me if I'm wrong).
