stunod2002
Dec 23, 2014Aspirant
Best use / max performance for dual LAN
I have the 2100 rack mount and would like to take advantage of the dual LAN on the device. Simply connecting both NIC's to the switch (A NTGR managed switch) will not do the trick I suspect. The main ...
RX
Dec 23, 2014Luminary
stunod2002 wrote: I have the 2100 rack mount and would like to take advantage of the dual LAN on the device. Simply connecting both NIC's to the switch (A NTGR managed switch) will not do the trick I suspect. The main reason I want to do this is I plan on using it as a DLNA server and I do not want the video streaming to impact other operations that could be taking place (IE file sharing, FTP, etc...).
Can the ports be Trunked at the switch thus giving 2 gig of throughput? Any other thoughts / ideas?
Thanks!
You may want to read this as reference guide: http://kb.netgear.com/app/answers/detai ... 3100,-3200,
If you have multiple users, Teaming or NAS bonding improves the performance. However, it will not improve performance if you only have a single user.
I suggest that you need to configure LAG on the NTGR managed switch first before you connect the bonded ReadyNAS ethernet adapters.
