stunod2002
Dec 23, 2014Aspirant
Best use / max performance for dual LAN
I have the 2100 rack mount and would like to take advantage of the dual LAN on the device. Simply connecting both NIC's to the switch (A NTGR managed switch) will not do the trick I suspect. The main ...
Dec 23, 2014Guru - Experienced User
Video streaming is actually not demanding, even full full bluray only requires 6-7 MB/s, and streaming typical HD downloads requires only 1-2 MB/sec.
Per http://www.readynas.com/?page_id=2276, the 2100 delivers about 85 MB/s (~700 mbits), so I don't think teaming will make much difference - it is not maxing out a single gigabit connection.
There's a chance ALB won't work well for you (note this thread: viewtopic.php?f=24&t=79162) So monitor the stats after you turn it on.
