herbg
Sep 08, 2013Tutor
Best way to backup 5TB of data on NAS
My ReadyNAS Pro Business Edition [X-RAID2] is using about 5TB of the 10TB available. I've been backing up my various folders/files using 3TB USB drives via FrontView Backup. This has worked quite w...
mdgm-ntgr
Sep 08, 2013NETGEAR Employee Retired
Backups to two USB disks (if you can move your data into groups of shares under 4TB) or backing up to another NAS unit would be the way to go. If going down the NAS route it could be a much cheaper NAS if you want to keep using the Pro as primary storage.
