herbg
Sep 08, 2013Tutor
Best way to backup 5TB of data on NAS
My ReadyNAS Pro Business Edition [X-RAID2] is using about 5TB of the 10TB available. I've been backing up my various folders/files using 3TB USB drives via FrontView Backup. This has worked quite w...
mdgm-ntgr
Sep 09, 2013NETGEAR Employee Retired
If you assign a static I.P. to the NAS (preferably using your router) you could specify the I.P. address as the hostname. The path would be e.g. "sharename/folder"
Like others, I recommend using NFS for full backups then changing the backup job properties to use Rsync for incrementals, if you are running the backup job on the Pro you would need NFS and Rsync enabled on the share on the backup NAS and vice versa.
