herbg
Sep 08, 2013Tutor
Best way to backup 5TB of data on NAS
My ReadyNAS Pro Business Edition [X-RAID2] is using about 5TB of the 10TB available. I've been backing up my various folders/files using 3TB USB drives via FrontView Backup. This has worked quite w...
Oct 04, 2013Guru - Experienced User
I wouldn't use RAID-0 for this anyway; it is too fragile. You could use the enclosure you already purchased if you connect it to your PC, and do the backup over the network using a robocopy script. robocopy will do incremental copies.
swamp2 wrote: I'm basically in the same boat. I have > 4TB of used space on my ReadyNAS NVX. I would like the least expensive solution possible to have 2 backup sets of my data. One set will be colocated with the NAS and use rsync once a week or so to keep the backup current. The other (hopefully identical solution) will be done every 6 months or so and taken off site for storage. Maybe not the ideal schedule for everyone and every application but should be super conservative for my needs.
-Obviously the simple solution I have been using of a single 4TB external USB drive is no longer viable
-I do not want to have to own 3 NAS devices to meet this goal
-I strongly prefer not to split folders, manage multiple external HDs and the like
-I've tried a two drive bay, hardware RAID0, external drive enclosure but it is not recognized with the full capacity by my NAS (http://www.readynas.com/forum/viewtopic.php?f=24&t=73113)
This is getting a bit complex and frustrating. Sure lots of money will solve the problem immediately. I'm hoping there is another option.
Thanks in advance.
Or get an RN102 with 2 3TB drives (jbod) to get automatic daily backups, and use the enclosure for the 6-month snapshots.
