howardg1
Aug 10, 2014Aspirant
Big mistake trying to move files between shares?
I am no networking expert but have been using my ReadyNAS duo successfully for over six years to share music, photos, and documents. I decided to re-organize file storage on the NAS so I went into Win...
Aug 13, 2014Guru - Experienced User
First try opening the "t" drive in two separate windows, navigate into two different shares, and dragging some files between the two windows. That should work like a fast move (be instant).
If for some reason it doesn't, then you can also do these moves using just one window - if you have your windows explorer layout configured to show you the navigation pane on the left.
