stevenestrada's avatar
Dec 10, 2017
Bigger RAID1
rn314 + os 6.9.1 + 4tb drives in two raid1 Is increasing raid1 easy as pulling a disk, putting in a bigger one, let it rebuild, then do the other? if not can you share the steps?
  • StephenB's avatar
    Dec 11, 2017
    stevenestrada wrote:
    I was figuring the new 6tb woukd rightsize iself to 4tb, and over and over and over.
    So that's not the case?
    When you upgrade the first 4 TB drive to 6 TB, the NAS will resync that drive.  The volume size will be the same as it is now - the extra space is wasted.
    After the resync completes, you upgrade the second drive to 6 TB.  First the drive will sync.  After a reboot, the system will create a new 2 TB RAID group to fully use the drive capacities.  That new RAID group will be added to your existing volume (so you will just see an increase from 4 to 6 TB).
    But if you simply added the two 6 TB drives to the RN314 (2x4TB+2x6TB) you'd have gotten a 14 TB volume.  If the 4 TB drives are healthy, you might consider that.
    FWIW, Sandshark missed that you were planning to upgrade both drives.
ProSupport for Business
