stevenestrada
Dec 10, 2017Aspirant
Bigger RAID1
rn314 + os 6.9.1 + 4tb drives in two raid1 Is increasing raid1 easy as pulling a disk, putting in a bigger one, let it rebuild, then do the other? if not can you share the steps?
- Dec 11, 2017
stevenestrada wrote:
I was figuring the new 6tb woukd rightsize iself to 4tb, and over and over and over.
So that's not the case?
When you upgrade the first 4 TB drive to 6 TB, the NAS will resync that drive. The volume size will be the same as it is now - the extra space is wasted.
After the resync completes, you upgrade the second drive to 6 TB. First the drive will sync. After a reboot, the system will create a new 2 TB RAID group to fully use the drive capacities. That new RAID group will be added to your existing volume (so you will just see an increase from 4 to 6 TB).
But if you simply added the two 6 TB drives to the RN314 (2x4TB+2x6TB) you'd have gotten a 14 TB volume. If the 4 TB drives are healthy, you might consider that.
FWIW, Sandshark missed that you were planning to upgrade both drives.
stevenestrada
Dec 11, 2017Guru - Experienced User
- stevenestradaDec 12, 2017Aspirant
thank you
