Ajfan
Oct 20, 2016Aspirant
Bit rot protection error within /var/log/journal/0/system.journal and cannot correct
Hi ! I just got this message on my RN 4220; Bit rot protection has detected an error within /var/log/journal/00d31b31fed446b688b7867645788512/system.journal and cannot correct the error. sh...
mdgm-ntgr
Oct 20, 2016NETGEAR Employee Retired
Which firmware are you running?
That looks odd. That's a log that's rotated after a period of time. I wouldn't have thought it should have bit-rot protection on it.
Can you send in your logs (see the Sending Logs link in my sig)?
Ajfan
Hi !
we are running firmware version 6.2.4
Logs are on the way !
Thanks !
// Aj
- mdgm-ntgrOct 21, 2016NETGEAR Employee Retired
That's very old firmware.
Do you have a backup?
I'd suggest getting your volume usage down to about 80-85% then updating to 6.6.0. - mdgm-ntgrOct 24, 2016NETGEAR Employee Retired
Any update? Did my suggestion above resolve the problem.
- AjfanOct 25, 2016Aspirant
hi!
no, not able to do it yet. We are moving all equipment in a few weeks and I hope it will run ok until then.
After that I will be able to redo/update the NAS.
// AJ
