simath
Oct 08, 2016Aspirant
Bonding/VLAN bug in 6.6.0
I have found a UI bug (IMO anyway) with the Network/Bonding/VLAN setup in 6.6.0. First the disclaimer (caveat): This is running on a modified, unsupported (ancient) Pro Pioneer, upgraded with a ...
JasonQ13
Oct 12, 2016Aspirant
I've seen a similar issue in a stock ReadyNAS.
What happens when you try to delete the VLANS?
14002089999?
- Kalle13Oct 22, 2016Tutor
Hi folks,
I`ll get the same error. After I click on delete to remove VLAN on my RN214 I get a cryptic long error number. Jut like JasonQ13. After that nothing changed.
Best regards
Kalle
