simath
Oct 08, 2016Aspirant
Bonding/VLAN bug in 6.6.0
I have found a UI bug (IMO anyway) with the Network/Bonding/VLAN setup in 6.6.0. First the disclaimer (caveat): This is running on a modified, unsupported (ancient) Pro Pioneer, upgraded with a ...
JasonQ13
Oct 12, 2016Aspirant
I've seen a similar issue in a stock ReadyNAS.
What happens when you try to delete the VLANS?
14002089999?
Kalle13
Oct 22, 2016Tutor
Hi folks,
I`ll get the same error. After I click on delete to remove VLAN on my RN214 I get a cryptic long error number. Jut like JasonQ13. After that nothing changed.
Best regards
Kalle
- FramerVOct 24, 2016NETGEAR Employee Retired
Hi Kalle13,
Would it be okay if you can also post a screen capture of the error message. The community might have more inputs regarding your concern.
- Kalle13Oct 25, 2016Tutor
Hi FramerV,
sure, no problem.
I hope you see everything.
Bestregards
Kalle
- FramerVOct 27, 2016NETGEAR Employee Retired
Hi Kalle13,
I am yet to try this out myself. Our LAB is being transferred as we speak, I will be trying to replicate this as soon as I can.
You could also try checking with NETGEAR support but I think you would be needing at least a per incident support for phone assistance.
