simath
Oct 08, 2016Aspirant
Bonding/VLAN bug in 6.6.0
I have found a UI bug (IMO anyway) with the Network/Bonding/VLAN setup in 6.6.0. First the disclaimer (caveat): This is running on a modified, unsupported (ancient) Pro Pioneer, upgraded with a ...
Kalle13
Oct 22, 2016Tutor
Hi folks,
I`ll get the same error. After I click on delete to remove VLAN on my RN214 I get a cryptic long error number. Jut like JasonQ13. After that nothing changed.
Best regards
Kalle
FramerV
Oct 24, 2016NETGEAR Employee Retired
Hi Kalle13,
Would it be okay if you can also post a screen capture of the error message. The community might have more inputs regarding your concern.
- Kalle13Oct 25, 2016Tutor
Hi FramerV,
sure, no problem.
I hope you see everything.
Bestregards
Kalle
- FramerVOct 27, 2016NETGEAR Employee Retired
Hi Kalle13,
I am yet to try this out myself. Our LAB is being transferred as we speak, I will be trying to replicate this as soon as I can.
You could also try checking with NETGEAR support but I think you would be needing at least a per incident support for phone assistance.
- evan2Oct 27, 2016NETGEAR Expert
Hi Kalle 13,
I reproduced the issue in local,
If create VLAN on bond, I saw the issue after reboot unit.
Issue only happen on bonding mode.
and will report to developer.
