Joesaar
May 15, 2019Tutor
Boot-failure on a ReadyNas Pro 6
I have been reading in the forum regarding this kind of problem and found that multiple users had a bit of luck when recieving a helping hand. My problem is from what I can tell the same, and was hop...
Joesaar
Jun 11, 2019Tutor
Finally been able to connect a monitor to the internal display header.
I am getting a "MBR H" error.
Also fully able to enter the BIOS and all those settings.
What would the next step be?
Sandshark
Jun 12, 2019Sensei
Sounds like a corrupted internal boot flash. If you can't boot to USB recovery, I don't know how to repair it. Maybe try booting with a gparted or other boot disk/flash (after changing the boot option in the BIOS, of course). I don't know if you can change the boot option in the BIOS to make it boot a USB recovery flash, but that's worth a try, too.
- JoesaarJun 12, 2019Tutor
So, I have now tried a LinuxLive USB and successfully booted that.
I have full network action and all other functions of the hardware.
I can see all the drives including the 128MB USB-drive that ìm guessing the readynas OS supposed to be running on?
Also found this thread that seems to have had the same issue and been able to use a "image" from another unit to have it restored?
- SandsharkJun 13, 2019Sensei
That does, indead, seem to echo your situation. And, if so, and assuming your flash memory is not damaged, that method will probably get you back up and running. The problem is getting an image that doesn't contain somebody else's serial number, now that mdgm is retired. Hopefully, another moderator can provide you with a usable image.
