rbrink
Mar 24, 2021Aspirant
Booting forever
I'm in the process of upgrading from 4.2.31 to 6.x though this is an unsupported process. My issue is the process appears to be stuck. It has been sitting at "Booting 92%" for almost 45 minutes. Anyo...
rbrink
I uploaded the 6.9.5 FW upgrade and started the process. I then had to reboot (message). After rebooting it started the FW upgrade and it stuck at 92%. After waiting almost an hour I shut it off and powered back on. This time it stalled at 46%. I repeated the same steps and it got to 98%. This time I started the boot menu and decided to do a factory reset since I haven't stored any data yet. It came right up after a few minutes. I ran RAIDar and after connecting it showed the OS at 6.9.5. Once I logged onto the server and went through the basic setup steps I was prompted with a message that there was an update available (6.10.4). The process bar is almost competed, with fingers crossed I should be at the latest/greatest. Thanks for the responses.
Mar 24, 2021Guru - Experienced User
Did you install prepr4tor6_0.1-x86.bin as an add-on first? Then install the firmware (as a manual update) and reboot?
prepr4tor6 eliminates the need to do a manual factory reset, but if you omit that step you definitely have to do the factory reset through the boot menu.
