anserk
Nov 03, 2017Aspirant
BTRFS is killing my NAS
I'm having major issues with btrfs in ReadyNAS. Every once in a while it just kills my NAS to a point where even typing SSH commands is very sluggish. Web UI and shares are not accessible. I've read ...
mdgm-ntgr
Nov 03, 2017NETGEAR Employee Retired
Which firmware are you running?
Have you disabled quotas at the volume level?
How full is your data volume?
anserk
Nov 04, 2017Aspirant
I'm running 6.8.1. I never enabled quota but reading forums it seems like it might have been enabled automatically by a certain firmware update. As part of the troubleshooting (and desperation), I pulled the plug and was able to log in via SSH, which was responsive despite btrfs-transacti process starting to eat up CPU. I had pulled the plug before - the system usually worked for a few minutes before stalling again. So this time I immediately issued this:
btrfs quota disable /data
It's been 15 minutes so far and I don't see any btrfs activity - all services are available.
Now that I can actually access the system, I looked at the GUI logs. The last entry is from snapshot prune worker from 11/2 23:19, the next message is from today when I restarted it. Logs in journalctl indicate there was an out of memory condition around that same time.
Here the output of some btrfs commands.
btrfs fi df /data
Data, single: total=3.84TiB, used=3.47TiB
System, DUP: total=32.00MiB, used=672.00KiB
Metadata, DUP: total=3.00GiB, used=1.74GiB
GlobalReserve, single: total=485.88MiB, used=2.91MiB
root@NAS:~# btrfs fi show
Label: '0e35c581:data' uuid: 07dfdef1-b26e-474a-b2ca-42a55738cb01
Total devices 1 FS bytes used 3.47TiB
devid 1 size 4.54TiB used 3.85TiB path /dev/md127
root@NAS:~# df -h /data
Filesystem Size Used Avail Use% Mounted on
/dev/md127 4.6T 3.5T 1.1T 76% /dataWhat is the best approach now to do any necessary btrfs maintenance? I had a monthly defrag which I disabled for now. I'm afraid to run balance as I had bad experience with it in the past (system locks up).
- mdgm-ntgrNov 04, 2017NETGEAR Employee RetiredThere is a GUI option to disable volume quotas and also an OS Re-install will disable volume quotas.
Volume maintenance should be scheduled during times where the NAS is being used lightly. Likewise with backups (obviously at a different time to volume maintenance).
Your volume usage is approaching the point where it would be a good idea to free up some space or expand the volume.- DonOKeeffeFeb 05, 2018Aspirant
results of btrfs filesystem df /Volume1
root@VegaNAS:~# btrfs filesystem df /Volume1
Data, single: total=2.68TiB, used=2.67TiB
System, DUP: total=32.00MiB, used=352.00KiB
Metadata, DUP: total=49.50GiB, used=33.51GiB
GlobalReserve, single: total=512.00MiB, used=200.03MiB- StephenBFeb 05, 2018Guru - Experienced User
GlobalReserve, single: total=512.00MiB, used=200.03MiBWhich shows it as being completely full - which is not good.
But what does running the same command on // tell you about the OS partition???
