anserk
Nov 03, 2017Aspirant
BTRFS is killing my NAS
I'm having major issues with btrfs in ReadyNAS. Every once in a while it just kills my NAS to a point where even typing SSH commands is very sluggish. Web UI and shares are not accessible. I've read ...
anserk
Nov 04, 2017Aspirant
I'm running 6.8.1. I never enabled quota but reading forums it seems like it might have been enabled automatically by a certain firmware update. As part of the troubleshooting (and desperation), I pulled the plug and was able to log in via SSH, which was responsive despite btrfs-transacti process starting to eat up CPU. I had pulled the plug before - the system usually worked for a few minutes before stalling again. So this time I immediately issued this:
btrfs quota disable /data
It's been 15 minutes so far and I don't see any btrfs activity - all services are available.
Now that I can actually access the system, I looked at the GUI logs. The last entry is from snapshot prune worker from 11/2 23:19, the next message is from today when I restarted it. Logs in journalctl indicate there was an out of memory condition around that same time.
Here the output of some btrfs commands.
btrfs fi df /data
Data, single: total=3.84TiB, used=3.47TiB
System, DUP: total=32.00MiB, used=672.00KiB
Metadata, DUP: total=3.00GiB, used=1.74GiB
GlobalReserve, single: total=485.88MiB, used=2.91MiB
root@NAS:~# btrfs fi show
Label: '0e35c581:data' uuid: 07dfdef1-b26e-474a-b2ca-42a55738cb01
Total devices 1 FS bytes used 3.47TiB
devid 1 size 4.54TiB used 3.85TiB path /dev/md127
root@NAS:~# df -h /data
Filesystem Size Used Avail Use% Mounted on
/dev/md127 4.6T 3.5T 1.1T 76% /dataWhat is the best approach now to do any necessary btrfs maintenance? I had a monthly defrag which I disabled for now. I'm afraid to run balance as I had bad experience with it in the past (system locks up).
mdgm-ntgr
Nov 04, 2017NETGEAR Employee Retired
There is a GUI option to disable volume quotas and also an OS Re-install will disable volume quotas.
Volume maintenance should be scheduled during times where the NAS is being used lightly. Likewise with backups (obviously at a different time to volume maintenance).
Your volume usage is approaching the point where it would be a good idea to free up some space or expand the volume.
- DonOKeeffeFeb 05, 2018Aspirant
results of btrfs filesystem df /Volume1
root@VegaNAS:~# btrfs filesystem df /Volume1
Data, single: total=2.68TiB, used=2.67TiB
System, DUP: total=32.00MiB, used=352.00KiB
Metadata, DUP: total=49.50GiB, used=33.51GiB
GlobalReserve, single: total=512.00MiB, used=200.03MiB- StephenBFeb 05, 2018Guru - Experienced User
GlobalReserve, single: total=512.00MiB, used=200.03MiBWhich shows it as being completely full - which is not good.
But what does running the same command on // tell you about the OS partition???
Results of btrfs filesystem df //
root@VegaNAS:~# btrfs filesystem df //
Data, single: total=1.23GiB, used=668.72MiB
System, DUP: total=8.00MiB, used=16.00KiB
Metadata, DUP: total=204.56MiB, used=9.78MiB
GlobalReserve, single: total=16.00MiB, used=0.00B
