LogicX
Feb 15, 2014Aspirant
btrfs locking at 74% on 6.1.6
I'm running 6.1.6 final - I STARTED with a fresh install and rebuild on a 6.1.6RC I had all my data offloaded; I started copying it back. I've since updated to 6.1.6 final. I am now copying it back...
mdgm-ntgr
Feb 16, 2014NETGEAR Employee Retired
Are you sure that's the leafsize for /dev/md127 not /dev/md0. Can you PM the full contents of btrfs.log
In the logs what does os_version.log contain?
From your initrd.log it looks like you are still running a RC?
What services are you using? Are you using iSCSI?
Do you have any apps installed?
