LogicX
Feb 15, 2014Aspirant
btrfs locking at 74% on 6.1.6
I'm running 6.1.6 final - I STARTED with a fresh install and rebuild on a 6.1.6RC I had all my data offloaded; I started copying it back. I've since updated to 6.1.6 final. I am now copying it back...
LogicX
Feb 16, 2014Aspirant
My apologies! Yes, I quoted /dev/md0 by mistake.
/dev/md127 says:
nodesize 32768
leafsize 32768
os_version.log: ReadyNASOS!!version=6.1.6,time=1390873255,arch=x86_64
I'm quite sure I upgraded to 6.1.6 final... but open to trying again if that does not appear to be the case.
no iSCSI
I have plex app installed
I use SMB, FTP, AFP, DLNA
I've managed to get to 80% usage; but my CPU usage spiked so high and never returned for hours -- I couldn't execute any commands and had to hard restart.
/dev/md127 11T 8.7T 2.3T 80% /data
/dev/md127 says:
nodesize 32768
leafsize 32768
no iSCSI
mdgm wrote: Are you sure that's the leafsize for /dev/md127 not /dev/md0. Can you PM the full contents of btrfs.log
In the logs what does os_version.log contain?
From your initrd.log it looks like you are still running a RC?
What services are you using? Are you using iSCSI?
Do you have any apps installed?
