LogicX
Feb 15, 2014Aspirant
btrfs locking at 74% on 6.1.6
I'm running 6.1.6 final - I STARTED with a fresh install and rebuild on a 6.1.6RC I had all my data offloaded; I started copying it back. I've since updated to 6.1.6 final. I am now copying it back...
JMehring
Feb 17, 2014Apprentice
I have version 0.9.9.2.374-aa23a69.
I think my problem is with nzbget now though. 98-99% of the time my load is fine. It just seems to be shooting up to a load of 20-30 every once in a while. Last time I just shut off nzbget and all went back to normal.
I wish there was a was to run iotop on this kernel. Maybe I will have to compile a version of the kernel myself :)
# iotop
Could not run iotop as some of the requirements are not met:
- Linux >= 2.6.20 with
- I/O accounting support (CONFIG_TASKSTATS, CONFIG_TASK_DELAY_ACCT, CONFIG_TASK_IO_ACCOUNTING)
