msq
May 10, 2016Apprentice
btrfs _merge_bio_hook error on RN104
Hello, TL;DR: Trying to recover from btrfs_merge_bio_hook+a4 error.Managed to boot into tech support mode and connect via telnet but btrfs restore and btrfs check returns "checksum verify failed...
SmplyUnprdctble
Jun 15, 2016Aspirant
Sliquid wrote:
Not that I'm aware of but I was given some info, if there were a way to SSH into the nas I would recover only the data I need and then dump the rest. But I'm not given proper info on how to enable SSH
I can get in through recovery / telnet.
But, the moment I try to mount md127, everything goes kaput with the btrfs_merge_bio_hook error.
I've tried the btrfs recovery things in here with no avail as well.
And, like this post, it's saying that one of my disks is missing, when it's clearly in it's spot.
If I remove one of the disks, I'd expect it to drop to degredated mode, but it boots completely and says I have New disks in the web interface.
kohdee
Jun 15, 2016Administrator
SmplyUnprdctble wrote:
Sliquid wrote:
Not that I'm aware of but I was given some info, if there were a way to SSH into the nas I would recover only the data I need and then dump the rest. But I'm not given proper info on how to enable SSHI can get in through recovery / telnet.
PM me your port number and I'll glance at it.
- SmplyUnprdctbleJun 16, 2016Aspirant
kohdee wrote:PM me your port number and I'll glance at it.
I sent a PM last night -- not sure if you've had a chance to glance?
