joey123
Jan 29, 2017Tutor
BTRFS scrub speed is insanely slow.
So I have a RN104, with about 10TB of disk space. When I set it to do a BTRFS scrub, the speed is horrific. I'm getting something like 30GB/hour of scrub speed. At the present rate, it would take ...
joey123
Jan 29, 2017Tutor
Replying to my own message, it's about 4GB/hour, not 30GB/hour. I let it run for roughly 3 days (~75 hours), and it finished a bit over 300 gb total.
Jan 29, 2017Guru - Experienced User
The last one I did took about 30 hours - that was on an RN526 with 4x6TB installed. That was using 6.6.1 beta.
- joey123Jan 29, 2017Tutor
That seems like a roughly plausible speed for this to be.
So, given that i have half as much data as you do, but my scrub is projected to take roughly 2,000 hours, is it really plausible that the CPU in the RN104 is 2,000 / 15 ~ 130x slower than the one in the RN526? Doesn't seem right to me.
There's definitely a bug here.
- mdgm-ntgrJan 29, 2017NETGEAR Employee Retired
Well one would need more info such as what services you are running, if you have any apps installed, disk SMART stats, logs zip from your system etc. before rushing to any judgments.
Nothing is running, and there's nothing wrong with the disks. I you have some ideas for logs that would be useful, I'm perfectly willing to post them up here. But all the standard culprits (AV, disk spin down, other things running, etc...) are not a factor. They are either totally off (AV, spindown), or really minimal (1 connected user, approx 0.0 kbps of activity throughout).
Also, this same thing happens if I run btrfs scrub start /data, straight from the commandline. So it's not completely limited to the readyNAS software itself, probably just part of a larger pathology within the Linux kernel. But it wasn't always this bad, it got about 10-100x worse about a year ago, presumably with one of the OS updates.
