joey123
Jan 29, 2017Tutor
BTRFS scrub speed is insanely slow.
So I have a RN104, with about 10TB of disk space. When I set it to do a BTRFS scrub, the speed is horrific. I'm getting something like 30GB/hour of scrub speed. At the present rate, it would take ...
aalexandrebeta
Feb 05, 2017Master
Try to disengage some features such as SMB or the others and re-run scrubs and balance to ease up a bit the CPU!
joey123
Feb 05, 2017Tutor
CPU usage is roughly 0.0% when I'm not running a scrub, and it's about 100.0% when I am.
It's not SMB that's causing these problems. When the thing is scrubbing, smbd is using less than 1% CPU. Essentially all the CPU time is going to the kernel tasks that are doing the actual scrub.
- aalexandrebetaFeb 05, 2017Master
try to disengage all the things then defrag, balance and scrub.
