joey123
Jan 29, 2017Tutor
BTRFS scrub speed is insanely slow.
So I have a RN104, with about 10TB of disk space. When I set it to do a BTRFS scrub, the speed is horrific. I'm getting something like 30GB/hour of scrub speed. At the present rate, it would take ...
Leia
Feb 17, 2017NETGEAR Employee Retired
I haven't reproduce your issue on my RN104 yet. The speed is 138MB/s. I want to fill more data in my box and try again. Do you mind change your WD drive and try again?
scrub status for 4814067b-f1a9-4dc2-afb2-99879e706058
scrub started at Fri Feb 17 04:05:24 2017, running for 01:01:51
total bytes scrubbed: 500.25GiB with 0 errors
scrub started at Fri Feb 17 04:05:24 2017, running for 01:01:56
total bytes scrubbed: 500.86GiB with 0 errors
scrub started at Fri Feb 17 04:05:24 2017, running for 02:22:16
total bytes scrubbed: 1.13TiB with 0 errors
scrub started at Fri Feb 17 04:05:24 2017, running for 02:22:21
joey123
Feb 17, 2017Tutor
Those numbers look very much in line with what I would expect, in fact a bit better than I would expect.
I'm ordering a new drive to replace the WD Green, and then we'll see. It will likely take me almost a week to get the new drive in, get the RAID rebuilt, and then do the test, so stay tuned.
- mdgm-ntgrFeb 18, 2017NETGEAR Employee Retired
Before you replace the disk I would suggest that you make sure that your backup is up to date.
- joey123Feb 22, 2017Tutor
Definitely wise. I've got everything backed up, pulled the green today and replaced with a helium filled WD Red 8TB, should be considerably better than the 3TB seagates I have alongside it.
The RAID is rebuilding, should take about a day, then I'll redo the scrub and see if it behaves any better. The green is still checking out as healthy, so not sure what I expect. Would be a bit surprised if this solved the problem. Probably still a bug either way. If the green is so bad as to slow things to a crawl, the system should be detecting that something is wrong, and I also would have expected it to affect (for instance) the RAID scrub as well.
Anyway, we'll see soon.
- aalexandrebetaFeb 22, 2017Master
glad to hear that the situation evolve!!
- joey123Feb 25, 2017Tutor
Disk is swapped, rebuild and reshape are done. Then I ran the scrub, and here's what I've got.
root@readyNAS:~# btrfs scrub status /data
scrub status for bfb437e8-16ee-444c-b4c8-48cee4f845e1
scrub started at Sat Feb 25 01:37:29 2017, running for 07:34:32
total bytes scrubbed: 60.08GiB with 0 errors
That's about 10 GB/hour. To do the whole ~4TB of data would therefore take roughly 400 hours, or about 20 days. This is pretty much the same as before.
This result isn't surprising, since we know it's not a hardware problem, because it was introdued by a software update.
Is there anyone at Netgear who can attempt to fix this bug?
- aalexandrebetaFeb 25, 2017Master
It's a hell of a mess you are into!!!!
Good luck and patience!!
Cheers!
Yeah, thanks.
The problem isn't devastating, because the NAS works just fine in every other way. I can even literally read every byte off it, and thus accomplish the scrub, in a reasonable amount of time. It's just the scrub functionality itself that is totally broken.
I guess let's see if Netgear tries to figure out a fix.
joey123you are learning the hard way and learning fast!!!!
In front of those kinds of mess I fell like a complete moron (excuse my French and I am a Frog as you noticed the way I slaughter the Cheakspear language!):)!!!
- StephenBFeb 26, 2017Guru - Experienced User
FWIW I just did a scrub on an RN52x NAS with 3x8TB disks in RAID-5. The volume has about 8.5 TiB of data on it. It was run from the web ui, so it was the btrfs scrub + raid scrub combination. The disks are all WD80EFZX.
The scrub took 31 hours. I didn't check CPU utilitization while it was running though.
