ibell63
May 15, 2017Aspirant
btrfs_search_forward+204, volume disappeared after a reboot
Came in this morning, found "btrfs_search_forward+204" on the screen, pulled power because I couldn't get to the admin panel for the NAS, it started up and everything was working. Started a scrub, s...
jak0lantash
May 18, 2017Mentor
On ReadyNAS OS6, the RAID array is built with mdadm. Then a BTRFS volume is built inside that virtual service.
(For X-RAID) In case of mixed HDD capacity, there is multiple mdadm RAID arrays, concatenated into a single BTRFS volume, in "single" mode.
So the stability of RAID56 features in BTRFS (RAID5 and RAID6) is irrelevant here.
In your logs, look at mdstat.log file, you will see the mdadm arrays.
