nik_k's avatar
nik_k
Bug Report: Firmware 6.4.0 - Permissions Manual Reset Error
Hi,
I have recently updated my readynas 316 to 6.4.0
Occassionly I have share permission issues and have to do a permissions reset.
However this is no longer working.
The error that comes up is:
facl_change fail uid=99 gid=99
Code: 1007130001
really need this to get fixed asap.
Is there any other way to fix the permissions.
This is the scenario:
I have access via SMP to Share2 but not to Share1 (see below as it stands now I just checked using ls -lsa)
0 drwxrwxrwx+ 1 guest guest 1018 Nov 23 05:42 Share1
0 drwxrwxrwx+ 1 guest guest  154 Jul 26 13:20 Share2
Once i reset the permissions using the manual reset above it works.
Any other ways? The only thing I can see differently is the 1018 compared to 154...not sure what that means... Any ideas?
FYI - I saw a similar error under another post about rsync. I tried to post there but now it wont let me for some reason. I had just deleted my account and added a new account (stuffed up my username) not sure if that caused the screw up of not.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You may wish to open an online support case about this.
    • nik_k's avatar
      nik_k
      Hmmm probably shouldn't of put solved as its not solved yet. But ill take your advice.
ProSupport for Business
