kcrossley
Dec 21, 2012Aspirant
Calculating network transfer speed?
What is the best way to calculate network transfer speed? Is there an app that does this?
kossboss
Dec 21, 2012Guide
Two ways:
1)For network attached storage check out iometer
Its complex when you first have a look at it. But its very extensive.
I would download the template file and the template file will run the tests.
The idea is you map a share to a drive and then run iometer on that drive letter and you get your write and read speeds across the network
Here is a forum article on how to setup a test:
http://www.readynas.com/forum/viewtopic.php?t=265
2)For network transfer speeds instead of focusing on drives and more on networking equipment diagnosis, use jperf (gui version of iperf) or iperf(which is a cli version)
Here is a nice guide on that
http://openmaniak.com/iperf.php
