kimbiel
Sep 16, 2020Aspirant
Can I swap disks between two ReadyNAS Pro 6 units.
One of my old ReadyNAS Pro 6 units died on me. It is totally unresponsive - I think that the powersupply died. I have 6x4 Tb of data which I need to save. I have an identical second unit which is wor...
- Sep 16, 2020
Welcome to the Community!
Your plan should be okay specially if you have drives to spare using on the RN528X to be initialized. You can then replace the drives of your working Pro 6 with drives of the one that died and be able to boot it normally provided that both are using the default OS4.2
You can also follow the procedure on ,igrating disk from 4.2 to OS6 if you want but IMO your plan would be fine.
https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
HTH
Sandshark
Sep 16, 2020Sensei
The NAS configuration is completely strored on the drives. So, assuming you have not updated just one to OS6, you can swap the drives and the second NAS will even report itself as the other one. The only thing that will follow the chassis is any IP reservation on your router, since that's linked to the hardware MAC address, not the software.
kimbiel
Thanks for the help. I swapped the drives from the dead unit to the living - it booted just fine and my data is safe.
