PWS442
Sep 20, 2015Guide
Can no longer write to External USB drive on ReadyNAS 314
I Can no longer write to External USB drive on ReadyNAS 314. Using version 6.2.4, and I have had a 4TB drive hooked up for a year now without problems. Even in the Shares tab I cannot delete, cut, no...
- Sep 22, 2015
.... And I did. Re-booting the PC allowed me to access, create, etc. The Mac did not require it.
Thank you.
mdgm-ntgr
Sep 20, 2015NETGEAR Employee Retired
Sounds like the filesystem on the USB disk may have been marked as dirty and hence it has gone read-only. You could connect the USB disk up to a PC and repair it using that.
PWS442
Sep 21, 2015Guide
Thank you. That allowed me to edit existing files, and to delete from "FrontView". However, I can no longer create folders, nor files from the PC. However, the Mac can do it. I will pursue this more later.
- PWS442Sep 22, 2015Guide
Thank you.
