R-March
Jan 10, 2022Aspirant
Cant connect to Nergear NAS RM104
Have NETGEAR Ready NAS RM104 for almost 7 yrs. No problems. Just before xmas saw msg disk 2 error. Disy defragmented. Installed new 3T disk thinking that system would rebuild the dir. But no luck. ...
Jan 13, 2022Guru - Experienced User
Not able to aacess the mail server menu.
- What exactly was the disk error?
- Are you seeing any volume errors?
- Are you able to download the log zip file from the logs page
- Can you clarify what you mean by the "mail server menu"? Are you talking about the email alerts configuration?
Also, what firmware are you running?
- R-MarchJan 14, 2022Aspirant
Had NETGEAR RM104 server for 7 tears no problem. Just before xmas, I notice msg saying Drive 2 was defragmented.
I took it of line and could not get back.
Replaced drive expecting system would rebuild it, but to no avail.
have about 7T of backed up files.
Any suggestiond appreciated.
I do not have any log files
runing ver 6.10.5
Is it possible to connect the drives to PC and use some kind of software to extract the files?
Roger
