oriordan
Feb 12, 2012Aspirant
Can't delete sparsebundle
I have been having problems with my Macbook Pro backing up to my ReadyNAS Duo since I came back from a trip. I realized I was inadvertently backing up VMWare Fusion images as part of the backup and...
mdgm-ntgr
May 02, 2012NETGEAR Employee Retired
Open Frontview (web-admin interface of the ReadyNAS). Go to Shares > Share Listing and add a new share (don't forget to click Apply).
Now if you want to do this on a Mac, connect to ReadyNAS (CIFS) as the "admin" (Frontview) user not your wife's user. You'll need to disconnect from the NAS first if you are already connected as another user. Once logged in as the "admin" (Frontview) user you should then see the C share. Move the sparsebundle across as I suggested then go to Frontview and delete the TMtemp share.
