oriordan
Feb 12, 2012Aspirant
Can't delete sparsebundle
I have been having problems with my Macbook Pro backing up to my ReadyNAS Duo since I came back from a trip. I realized I was inadvertently backing up VMWare Fusion images as part of the backup and...
logger
May 03, 2012Aspirant
Oh shoot me how did I miss that. Now I get you. So I successfully created the TMtemp Share on the readynas nv. It shows up as it should from both my PCs and Mac across the network. Next problem is that when I try login in as the readynas admin (now I get what you mean there too) I cannot see the C share. I see my 6 original shares plus the new TMtemp but no C share. ie the same as I would see if I login as a guest
I vaguely recall accessing the C share from a PC in the distant past. Is it perhaps better I do it from there?
Thanks for the help BTW.
