oriordan
Feb 12, 2012Aspirant
Can't delete sparsebundle
I have been having problems with my Macbook Pro backing up to my ReadyNAS Duo since I came back from a trip. I realized I was inadvertently backing up VMWare Fusion images as part of the backup and...
mdgm-ntgr
May 09, 2012NETGEAR Employee Retired
SSH in and do
This would delete all the TM sparsebundles. If you just need to delete one then you can specify the name of the sparsebundle.
Using SSH is the fastest method if you are familiar with it, but not everyone is comfortable with using SSH.
cd /c/.timemachine
rm -rf *.sparsebundle
