dirkdigs
Jan 01, 2015Aspirant
cant go faster than 12 MB/s
i copy alot of data over my network to my ready nas ultra 4 plus i cant get any faster than 12 MB /s (100 Mbit/s) >>> basically using 10% of gigabit LAN. is this normal should i be getting faste...
Feb 06, 2015Guru - Experienced User
I'm not sure what scenario delivers 200 MB/s.
meverz wrote: Or wait an go with the ReadyNAS 200 series that Netgear have announced, it is supposed to be capable of up to 200MB/s which should be enough to max out Gigabit. Though the question then becomes, what are you doing that requires maxing out Gigabit?
I am running jbod, and I get about 80 MB/s write and 95 MB/s read with NasTester. The disk is a WD60EFRX, snapshots and bitrot protection are turned off for the share, and AV is also off for the system. That's pretty similar to the RN300 series.
