vrspectre
Jan 14, 2015Apprentice
Can't switch to dual redundancy
I just got a new 516. It's so much faster than my NV+. I think I'm really gonna like it. I put 3x4TB WD Red drives in it. I setup all my shares and everything is working. I've got a 4th 4TB WD Red...
mdgm-ntgr
Jan 14, 2015NETGEAR Employee Retired
Switch to Flex-RAID.
If you don't have data on it then delete the existing volume and create a new RAID-6 one using all four disks, then click on the X-RAID button again and re-enable X-RAID. This will be fastest.
I recommend calling the volume 'data' (no quotes, case-sensitive) as some apps may still expect the volume to be called 'data'.
