vrspectre
Jan 14, 2015Apprentice
Can't switch to dual redundancy
I just got a new 516. It's so much faster than my NV+. I think I'm really gonna like it. I put 3x4TB WD Red drives in it. I setup all my shares and everything is working. I've got a 4th 4TB WD Red...
mdgm-ntgr
Jan 14, 2015NETGEAR Employee Retired
Switch to Flex-RAID, add the fourth disk, delete the existing volume then create the new one using all four disks etc.
I guess you could try that.
If you don't want to set things up again you could wait for the sync to complete with the three disks, switch to Flex-RAID and you should see the option to convert the volume to use RAID-6 with the fourth disk.
