karishmadan
Sep 14, 2016Aspirant
cant sync ready nas with samsung tv
u was using plex on my samsung tv up until recently and now for some reason i cant use the plex app on my samsung i have plex pass is there any way to solve this problem also plex keeps asking for an...
Sep 14, 2016Guru - Experienced User
What version of the plex server are you running?
It is possible that you are being affected by this:
IMPORTANT: With the security changes in version 1.1.0, if your Plex Media Server is signed in to a plex.tv account, then all of the apps you use must also be signed-in. If you use older apps that cannot authenticate (e.g. LG's MediaLink or SmartShare apps), you can add the IP address of the device to the following advanced preference:Settings > Server > Network > List of IP addresses and networks that are allowed without auth.(We strongly encourage apps to be signed in for improved security and enhanced functionality.)
Though the plex release notes don't mention it, if you are going to add your TV's IP address to the server configuration, then you should either reserve the TV's address in the router or make it static. Reserving in the router is best.
You can download plex server for ReadyNAS OS 6 systems from https://www.plex.tv/downloads/ Select "netgear" as the platform, it will give you a couple of options (x86, arm, RN2xx arm) after that.
- karishmadanSep 14, 2016Aspirant
im using this version
Version 0.9.11.7 An update is available. Please install manually.
but i cant update it and i cant sign in also when i try it says theres a prblem signing in
ive tried downloading those what shd i do once they download nothing seems to work
- StephenBSep 14, 2016Guru - Experienced User
Download to your PC and then install on the system->settings page (manual firmware install).
- karishmadanSep 14, 2016AspirantServer MappingPrivate Unknown IP Public Unknown IP Internetnone of this is connctedsorry to flood u with replies
