karishmadan
Sep 14, 2016Aspirant
cant sync ready nas with samsung tv
u was using plex on my samsung tv up until recently and now for some reason i cant use the plex app on my samsung i have plex pass is there any way to solve this problem also plex keeps asking for an...
karishmadan
Sep 15, 2016Aspirant
What sort of work is it super technical??
- mdgm-ntgrSep 15, 2016NETGEAR Employee Retired
The instructions are in post #3 in this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/td-p/897021
You do need to backup your data first.
Then install the R4toR6 Prep add-on, then install the R4toR6 firmware image. The NAS will verify the image and prompt you to confirm you wish to reboot to install it. The NAS will automatically do a factory reset at the appropriate time avoiding the need for you to use the boot menu to do one manually.
Then you would restore your data from backup.
