bedwardsnexlear
Sep 12, 2011Aspirant
Case #16666541, NV+ stuck "Booting..."
Device: ReadyNAS NV+ (Model: RND4000) First off, everything is backed up 100% so I'm not worried about losing data. I'd just like to get this ReadyNAS working again ASAP. On Saturday a new tech ...
bedwardsnexlear
Sep 13, 2011Aspirant
Went ahead and bit the bullet with an OS reinstall from the Reset button. Worked like a charm. The NAS is back 100%. Only now I have the problem of copying in the data that was changed on the backup NAS. 99% of what's there hasn't changed, I am certain. Does anyone know of software that would compare both NAS shares and copy only the files with newer timestamps? The alternative is deleting everything from the ReadyNAS and running a backup to copy in the data from the backup NAS overnight. Which is fine, too.
If someone from Netgear is reading this thread, I think you can go ahead and close the case. I never did hear back from them but that's OK.
Thanks for any ideas you may have regarding merging the two data sets!
