cul8
Nov 19, 2011Aspirant
Case: 17190439 - Lost disk on uppgrade to 4.18 [CLOSED]
Readynas NV+ (V2) with 3 1TB disk was working with no problems. Uppgraded to 4.18 and all went ok, unti asked for reboot and then: After reboot disk 1 started to blink on green LED and ended after m...
mdgm-ntgr
Nov 20, 2011NETGEAR Employee Retired
The disk failure and firmware update are likely coincidental. 4.1.6 and earlier have some compatibility issues with WD Green disks. Also the WD10EARX is not on the compatibility list and may have compatibility issues.
Have you contacted NetGear tech support for assistance? Trying to fix the problem yourself is likely to only make it worse and reduce chances of data recovery.
