cul8
Nov 19, 2011Aspirant
Case: 17190439 - Lost disk on uppgrade to 4.18 [CLOSED]
Readynas NV+ (V2) with 3 1TB disk was working with no problems. Uppgraded to 4.18 and all went ok, unti asked for reboot and then: After reboot disk 1 started to blink on green LED and ended after m...
cul8
Nov 20, 2011Aspirant
Case: 17190439
Disc sync ended upp again in Disc 1 failure.....
I know now that WD10earx is not comp. I read on the wrong compatibility list. Any way initial disc 1 is ST31000340AS and been working for a while, have tested it and reports no fault.
I have opened a support case
