karlblomquist
Dec 21, 2011Aspirant
case:17437017 NVX 4 x 3TB = only 7408GB. Should be 8100+GB?
I recently expanded drives on one of our NVX systems to 4 3TB drives. Raidar shows each drive being 2794GB in size. However we are only getting 7408GB total usable space on the system - it s...
mdgm-ntgr
Dec 21, 2011NETGEAR Employee Retired
Is this really what partition.log looks like?:
On my ReadyNAS I see Linux RAID in the Name column on these lines.
I would suggest opening a tech support (http://www.readynas.com/support) case. They should be able to look at your logs and work out what's going on.
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
5 9437256 3907024064 1.8 TiB FD00
6 3907024072 5860529038 931.5 GiB FD00
